try to drive, but no power?
Old Feb 2, 2012 | 07:37 PM
RMitch's Avatar
Question try to drive, but no power?
Have a 1995 4x4 3.2l rodeo and was driving home the other day, then just started loosing power! Now it will start, but idles very ruff! when I try to drive it dies! Have checked fuel pump for gas pumping(checked), changed wires and plugs(checked), catalytic converter(checked), no sign of blown head gasket! no check engine light but it may be burnt out! My next move is to clean TB, do computer diagnosis, check compression in each cylinder! Is there anything else I should look at? any advice would be helpful, thanks
Old Feb 9, 2012 | 05:49 PM
RMitch's Avatar
Angry
well dont know if this is a dead forum or what, but can someone at least tell me if the 3.2l can slip a notch or 2 and still start but not run? Thank you again
Old Feb 10, 2012 | 10:55 PM
hbrian9's Avatar
sounds like a timing issue, how many miles is on it?
Old Feb 10, 2012 | 11:56 PM
RMitch's Avatar
about 220,000! well thats what the it says but the motor looks in to good of shape to have that many miles! had a little over 130,000 when he got it....
Old Feb 15, 2012 | 04:30 PM
panther.stealth's Avatar
ecm diagnostic best bet.
Old Feb 23, 2012 | 02:12 PM
czankl's Avatar
I'm having the same problem on my 99 rodeo
WheelsMike
Wheels and Tires
Jun 11, 2013 06:55 AM
jleland
Jun 25, 2009 08:43 PM
Christine
Aug 24, 2006 04:59 PM
