timing question
Old Jan 3, 2009 | 12:08 PM
1998rodeo's Avatar
I have to replace my water pump (new belt and water pump less then a year old). Is there a way to lock the cams so that when I remove the belt it will stay timed??
thanks for the replies
Dean
Old Jan 5, 2009 | 06:54 AM
Sorry I didnt reply sooner, computer problems [img]smileys/smiley19.gif[/img]
As far as I know there isnt a way to lock them in place but you might be able to come up with something to hold them in place. Or see how far they move and try to put it back the same. If you arent able to do either, here is a quote from Jerry (who knows everything isuzu) on how to set the timing on 2nd gen rodeo 3.2 engines..
OK STEVE LETS DO IT THIS WAY , FORGET THE MANUAL , YOU CAN USE IT WIPE YOUR HANDS WITH WHEN YOU GET THRU, TURN THE CRANKSHAFT SO THAT THE KEYWAY IN THE CRANKSHAFT IS SET AT 3.0CLOCK THERE IS A LINE ON THE OIL PUMP TO LINE THIS ONE UP WITH, THIS ONE IS EASY THE SLASH MARK ON THE EDGE OF THE LOWER TIMING PULLEY GOES OVER TO THE 9.0 CLOCK POSITION, NOW ROTATE THE CAM PULLEY ON THE RT BANK CLOCKWISE AND IT WIL GO THUMP THUMP MAYBE 5-7 TURNS BEFORE IT WILL LINE UP , DEPENSD ON WHER IT IS NOW , LINE UP THE TIMING MARK ON THE PULLEY WITH THE MARK ON THE VLV CVR IT WILL BE RIGHT BETWEEN THE TWO SEALS IN FRT ALLSO THE KEY WAY IN THE CAM GEAR CAN BE USED AND IT SHOULD LINE UP WITH THE MARK ON THE PULLEY,, NOW ON THE LFT BANKTAKE A CLOSE LOOK AT THE TIMING MARK ON THE VLV CVR SAME SPOT AS ON THE RT BANK, LOOK TO THE LEFT OF THIS MARK FOR A MARK ON THE CYL HEAD ITSELF NOW ROTATE THE CAM GEAR AROUND WHAT EVER NO OF TURNS IT TAKES TO GET THE MARK TO LINE UP, WITH THE MARK ON THE GEAR AND THE CYL HEAD OK ,, NOW ROTATE THE SAME GEAR CLOCKWISE UNTILL THE CAM GEAR MARK LINES UP WITH THE MARK ON THE VLV CVR , THE REASON YOU HAVE TO TURN THES THINGS SO MANY TIMES , IS THE CRANK SHAFT OBVISOULY HAS TO TURN TWICE FOR EVERY CAM SHAFT TURN CORRECT WELL ON THESE ENGS THE RATIO FOR THE CAM TO CRANK IS NOT 2.1 IT IS 1.57 TO ONE , HOW CAN THAT BE , THE RATIO IS PICKED BACK UP INSIDE THE HEAD WITH THE CAM GEARS INSIDE THE HEAD TO BRING IT BACK TO THE 2.1 CAM TO CRANK ,, THIS WAS DONE TO LOWER THE CYL HEAD HEIGHT , SOMETIME TAKE A LOOK AT THE OVERALL HEIGHT OF THIS ENG COMPARED TO THE OLD ER 3.2 SOHC OR THE DOHC ENG THIS ENG IS ALLMOST 3INCHES SHORTER IN HEIGHT , THERE ARE NO ROCKER ARMS NOLIFTERS NO ROCKER SHAFTS , THE CAMS RUN RIGHT ON TOP OF THE VLV STEM THRU A BUCKET TYP SDJUSTER THAT SITS ON TOP OF THE CAMSHAFT, NO A NEW DESIGN BY ANY MEANS BEEN AROUND FOR EVER BUT NOT IN THIS TYPE OF AN ENG ,,, ANYWAY NOW PUT THE BELT BACKON AND RELEAS THE TENSIONER AND YOU SHOULD BE IN GOOD SHAPE , BY THE WAY THESE ENGS WILL RUN ON 3 CYL ON ONE BANK RELATIVELY SMOOTH. JERRY
doccallahan
Apr 2, 2009 10:20 PM
SteveC
Sep 17, 2008 07:01 AM
Sniper X
Jul 22, 2008 12:32 PM
alanrush2004
May 28, 2008 01:09 AM
Harleygirl
Jun 15, 2005 05:31 PM
