Spare Tire Delete?
Old Sep 16, 2011 | 05:54 PM
jacobg128's Avatar
Default Spare Tire Delete?
Hey all, I have a 96 Rodeo with the spare mounted on the swinging bracket on the back. Lately, if I hit a good bump, it comes loose from the back door and swings out. I've adjusted the latch as much as it will go, and gotten nowhere. The bolts on the bottom of the bracket that holds the arm, seem to be stripped. Anyone have any experience with this? What's the fix?
Old Oct 13, 2011 | 10:40 AM
Taylorcarter's Avatar
good job juys
Old Oct 15, 2011 | 07:30 AM
TM2001RODEOSE's Avatar
Would start with replacing stripped bolts, etc to eliminate any free-play in the tire carrier. Bumps likely causing deflection in brackets ,tire carrier, and causing misalignment in bracket that prevents unlocking of swing function of carrier.
Replace with new fasteners and I bet this solves the problem.
Good luck
wondergeek
Private 'Wanted' Classifieds
Nov 30, 2009 10:20 PM
96isu
Sep 9, 2009 04:21 AM
gigglehush
IF Help & Suggestion Center
Mar 28, 2008 09:14 AM
skipy
May 17, 2006 03:06 PM
robinsky
Aug 30, 2005 02:23 PM
