Roof rack light pics
Old Jun 15, 2008 | 03:41 PM
Sorry to start a new topic for this. Was having trouble getting it to post as a reply in the right thread.
Front lights mounted. I just drilled holes in the flat parts of the rack to mount them...
Ran the wires for front lights into the B pillar, under the head liner, then down the A pillar. Right where I drilled the hole is the edge of another piece of metal behind there so made drilling harder then expected..
Rear work/reverse lights and cb antenna mounted. I used some straight steel brackets I got from home depot to mount the lights. Just painted, mounted to the bottom of the rack, then drilled the holes for the lights...
I ran the wires through the rear hatch glass. There is enough clearance that its not a problem. For the cb antenna I used an existing grommet. For the light wires I drilled another hole lower and used a rubber grommet...
Hope this helps.Edited by: Gizmo42
Gdafpaaa
Jun 28, 2011 04:52 AM
Yardie2006
Apr 28, 2010 06:01 PM
tp_mantis
Aug 29, 2008 10:44 AM
RyJen
Jun 15, 2008 07:30 AM
mcputman917
Nov 21, 2006 09:41 PM
