4 Attachment(s)
Sorry to start a new topic for this. Was having trouble getting it to post as a reply in the right thread.
Front lights mounted. I just drilled holes in the flat parts of the rack to mount them... Attachment 1196 Ran the wires for front lights into the B pillar, under the head liner, then down the A pillar. Right where I drilled the hole is the edge of another piece of metal behind there so made drilling harder then expected.. Attachment 1197 Rear work/reverse lights and cb antenna mounted. I used some straight steel brackets I got from home depot to mount the lights. Just painted, mounted to the bottom of the rack, then drilled the holes for the lights... Attachment 1198 I ran the wires through the rear hatch glass. There is enough clearance that its not a problem. For the cb antenna I used an existing grommet. For the light wires I drilled another hole lower and used a rubber grommet... Attachment 1199 Hope this helps.Edited by: Gizmo42 |
