Rodeo Question
Old May 19, 2008 | 07:14 AM
lomac9's Avatar
This is my first post here and would like thank ahead of time for any info. I have read back into the posts here about engine idle on 98 rodeos and notice that every one of these posts have no replies. The issue is the vehicle will idle fine some time and other times will increase to 2000 -2500 rpms in park. Was wondering if anyone could give me and others some solid info on this seemingly common problem. thanks again
_uacct = "UA-939292-44";
Old Nov 17, 2008 | 08:38 PM
parra's Avatar
You right, this are a commun problem , I also Have the same issue.
Already change twice the IAC valve and the problem remain, somebody told Me that could be the intake gasquet, but I´m not sure because if Where the case , I think the problem will be constant and isn´t.
I also change the EGR and still ...
We really need an expert.
COULD SOMEBODY HELP???????
Old Nov 18, 2008 | 09:50 PM
triguy's Avatar
check all vacum hoses, leak hose well sometime do that or gasket leak on intake manifold,[get pronpane tore turn it on without fame just gas if it rpm go up it someplace on the in take there your leak,]speed senor could be going bad,i think it mostly vacum hose,make it run up and down,ive been working on car for over fifty years, [signed guy]; with my 1994 rodeo it eat my lunch,wont rpm up and startes hard im looking in to the pks, postion senor on the crank, gt Edited by: triguy
Old Nov 18, 2008 | 11:53 PM
parra's Avatar
Hi,thanks to triguy for the alternatives, I will verified again the vacum sistem ( My mechanic already did) but We will double check.
Do think that the speed sensor could be damage ??
THANKS AGAIN FOR YOUR HELP.
BEST REGARDS...
doccallahan
Apr 2, 2009 10:20 PM
markjw
Oct 9, 2008 12:34 AM
spearbang
Aug 11, 2008 04:59 PM
alanrush2004
May 28, 2008 01:09 AM
Harleygirl
Jun 15, 2005 05:31 PM
