Rodeo problem
Old Aug 28, 2022 | 10:45 AM
Bluetrees's Avatar
Default Rodeo problem
Isuzu Rodeo 2.5 2010 plate. Starts and runs fine for about 10 mins, pulls and revs properly. But if you then drive it really hard it starts to loose power and engine sounds rough. If you then ease off a bit the power increases but not back to normal. If you try to keep driving it hard the power gets gradually worse until the engine malfunction light comes on code 299. Changed fuel filter, egr valve, boost pressure sensor and boost pressure solenoid as that is what the error code is for but no difference. Any ideas what the fault is. Fuel pump appears to work fine but think it's got to be a fuel problem. Cheers.
mooseye
May 29, 2012 03:41 PM
keith5strick
Dec 16, 2011 07:48 PM
newrodeo
Jun 16, 2011 08:20 PM
tstratton
Jun 12, 2008 11:41 PM
larsthegamer
Jul 20, 2007 02:55 PM
