Poor Acceleration
Old Aug 10, 2009 | 02:18 PM
kenc195's Avatar
Default Poor Acceleration
1997 V6 2WD, 225,000 miles, 30,000 miles on timing belt.
Very sluggish acceleration, especially when the AC is on. To run at highway speed I need to have it in "Power Mode". New Denso Plugs, new air filter, no trouble codes and no check engine light on. Went from 16MPG down to 13. This has me stumped.
Old Dec 10, 2009 | 08:17 PM
bizzo's Avatar
Hey Ken-
I've got the same problem with my 2006. I've got about 235K, and around 40 miles on the timing belt... I'll be interested to hear what someone has to say about it. I tried changing the fuel filter (super easy) but that wasn't it. then went through the rest of the other "usual" things but no difference...
Old Dec 11, 2009 | 10:19 AM
kenc195's Avatar
Default Several things happened at once
1. Valve cover leaks around the spark plug wells caused the rubber on the plug extensions (comming off the coil pack) to allow shorting. new gaskets and 4 new coil packs fixed that part.
2. The keyway on the harmonic balancer sheared and the balancer began to drift. This effects the timming and eventually it just died. All in all, $2000.00 or do fixed it and it runs good now.
Old Dec 12, 2009 | 03:52 PM
96isu's Avatar
just a suggestion cleaning the mass air flow sensor with spray you can buy at autozone or kragens makes a big difference in terms of acceleration and fuel milage
Old Dec 23, 2009 | 10:11 AM
Algopsy09's Avatar
If any one sees Danf05 join the IRC then say oh dear poor poor fisher
Any 1 listenin to Ricos cover will know what im on about
jeffblack
Isuzu Pickup, i-350 and 1-280
Jan 2, 2013 08:49 AM
havardur
Sep 20, 2008 10:40 AM
GOLON
Jun 22, 2008 07:31 PM
biggreen
Mar 18, 2007 07:59 PM
sick trooper
Mar 19, 2006 12:12 PM
