Not your average neutral safty/mode selector switch problem
Old May 19, 2011 | 11:32 AM
Smittysmymechanic's Avatar
Default Not your average neutral safty/mode selector switch problem
I have been a mechanic a long time. I have a prob . 99 Isuzu rodeo has wired shift problem. When in park dash shows park when in reverse it shows park when in neutral it shows nothing when in drive it shows low when in 3 or 2 it shows 2 and in low it shows low. I changed mode selector switch 3 times now and each time it works koeo then she drives it 100 yards and the lights screw up. Each time it's the same. Is this a possible ECM or tranny issue or maybe you have a diagnostic procedure I could grab from ya. Any advice would be helpful.
Old May 19, 2011 | 04:00 PM
newrodeo's Avatar
I have not seen this problem either but it almost sounds electrical problem.
When in the correct gear does it act up or it shifts fine????? have you done any work under the dash?? check your ground wires there is a main ground under the dash and also their is on next to the ECM try thoes....
Old May 25, 2024 | 10:26 PM
Todd 13's Avatar
Default 2001 Isuzu trooper
Driving home from work and I lost my park reverse neutral drive light's on my dash and then my transmission was acting up and then My turn signals went out . What could this possibly be l!!
rodeodad
Oct 6, 2017 06:28 PM
anav95
Jan 2, 2014 06:03 PM
jross61975
Nov 18, 2007 10:07 PM
sawcut64
Sep 14, 2007 06:38 PM
thomasd
Jul 1, 2007 09:33 AM
