More Fuel And Power 92 rodeo 3.1 V6 Help?
Old Nov 12, 2010 | 10:25 AM
Tobyjd's Avatar
Default More Fuel And Power 92 rodeo 3.1 V6 Help?
i'm Looking to turn up my fuel on My 1992 Rodeo Ls 3.1 L V6 i want more power can anybody help?
Old Nov 14, 2010 | 03:23 PM
hr2burn's Avatar
You mean making it run richer? That for sure would not give more power. You need something forcing more air in as well. Then you would need tuning, perhaps more timing. So now your talking forced induction (turbo, supercharger etc...) I really doubt stock internal could handle much boost at all. Perhaps, look into some sort of hi flow cold air intake, maybe pulstar spark plugs, better spark plug wires...I'm pretty sure hp gains would be pretty minimal (maybe neighborhood of 10hp?) good luck with your endeavor, I'd be happy to help anyway I can!
Old Nov 15, 2010 | 09:14 AM
Tobyjd's Avatar
i did upgrade my air intake with an 10" edelbrock chrome pan intake for easier air flow. i have 4.55 gears in the rearend which is killing my speed (30-60) im also looking to put a plow on it i upgraded my front suspension to a heavy duty coil over strut but im not sure they make a plow for it so i didnt know if i could modify one from a blazer or another similar vehicle
Old Nov 16, 2010 | 09:24 AM
hr2burn's Avatar
I see your issues..
Your adding more weight, changing gearing because of this, plus having more low end tq for plowing. I think you would need ALOT of power to offset this. I mean look at an 18 Wheeler... tons of power, tons of weight but 20 plus gears....
Without dumping a butt load of bank, I think your kinda between a rock and a hard place.
Old Nov 17, 2010 | 04:59 PM
Tobyjd's Avatar
my 4.555 gears came stock all im wanting to know is if it possible to attach a snow plow i believe its got the torque to do it i can pull 1 ton trucks out of ditches and what not
Old Nov 17, 2010 | 05:01 PM
Tobyjd's Avatar
if speed was not going to be easy to come by my next project is putting on a plow
jamnjm
Jul 19, 2009 12:41 AM
Thinglenn40
Apr 13, 2009 10:05 PM
compfreak530
Sep 13, 2008 05:55 PM
Gizmo42
Dec 6, 2006 12:51 AM
Silver2001Rodeo
Jan 21, 2006 07:47 PM
