MISFIRE IN ENGINE
Old Nov 18, 2007 | 11:08 PM
RSTIEBER's Avatar
I HAVE A 2004 RODEO 3.5L WITH 44000 MILES. MY CHECK ENGINE LIGHT CAME ON AND THE ENGINE IS RUNNING A LITTLE ROUGH. CODE IS MISFIRE IN CYLINDER 4. I REPLACED THE SPARK PLUGS WITH NO EFFECT. SHOULD I CHECK THE INJECTION BOOT NEXT OR THE INJECTOR, AND HOW DO I DO THAT? THANK YOU VERY MUCH - RUSS
Old Nov 21, 2007 | 01:55 PM
jetmech09's Avatar
you should pull the electical conector of the coil pack on #4 cyclinder to see if it firing or swap coil packs with another cyclinder to see if the problem changes over to the swaped cyclinder.
Old Nov 23, 2007 | 06:02 PM
RSTIEBER's Avatar
thanks i'll try that.
xcountrycowboy
Jan 3, 2013 12:08 AM
Tater1945
Jan 30, 2010 02:53 PM
pookoo
Sep 3, 2007 06:01 PM
hilbili
Jul 20, 2007 02:50 PM
JohnJoseph
IF Help & Suggestion Center
Oct 10, 2006 01:51 PM
