Help!!!!!!!
water in the oil is a pain in the butt, but as posted above, you need to do oil changes, and it may take a few. Since the water was put in the oil pan, and the oil hasn't circulated the engine you may be in luck.
Drain and change the oil, then run the car for a minute, and drain and change the oil. Then run the car for 5 minutes, and drain and change the oil and see how she does.
Good luck!
Good luck!
