Ghost in the machine
Old Jan 29, 2011 | 05:36 PM
justpow's Avatar
Default Ghost in the machine
My 99 rodeo just started doing some wacky stuff, the headlights dont work, neither does the FR signal, the indicator works, but intermitantly, and either fast, slow or not at all. The blower cuts out when the wipers are turned on which also dont work.
Anybody ever run into these problems before? Are there any particular problem areas or grounds that I should check?
Old Feb 3, 2011 | 08:41 PM
justpow's Avatar
Problem fixed, turned out to be a bad ground.
