Gas meter has life of its own
Old Feb 6, 2007 | 08:47 PM
98rodeoS's Avatar
All the other electrical seems OK, but the gas meter light is on when the meter reads it is full, and the meter itself will bounce around from full to empty. Does not seem to matter if it was just started, or going up a hill or down a hill, just totally random. Any ideas where to start? Ordered auto guide just now
Old Feb 6, 2007 | 08:49 PM
MASTERTECH's Avatar
You have a fuel sender problem, if you have a 98 model you will need to take it to the dealer and have the pcm reprogrammed
Old Feb 6, 2007 | 09:20 PM
98rodeoS's Avatar
Thanks very much.
Old Feb 7, 2007 | 05:13 PM
98rodeoS's Avatar
Dealer will not reprogram PCM. I've tried a fuel additive, but it sounds like i'll need to replace the fuel sender.
Old Feb 7, 2007 | 10:43 PM
MASTERTECH's Avatar
after the sender is replaced, it will need to reprogrammed or it will not work, find another dealer or contact upper management
Old Mar 19, 2007 | 06:39 PM
98rodeoS's Avatar
Replaced fuel sender using Awnicol25 or something like that from ebay. $35 dollars and used link below for instructions to replace. By the Haynes manual it looks like the sender is at the back of the gas tank, but it is actually on the top and a bitch to get to. Like the article says, only problem was lowering the tank. May be good advice to get a mask, I think i killed about a billion brain cells huffing gas fumes for a half hour. to each their own[img]smileys/smiley8.gif[/img]
</span>planetisuzoo - Replacing the Fuel Sending Unit on a 2nd Gen Isuzu Rodeo
Old Mar 19, 2007 | 06:42 PM
98rodeoS's Avatar
Oh and despite my name, it is a 99 model, and i did not have to reprogram PCM
99Trooper804
Exterior
Nov 21, 2012 08:43 PM
bali kute
Jun 28, 2011 02:42 AM
gerdewae
Feb 19, 2009 05:10 AM
shawnferg23
Aug 12, 2008 11:53 AM
