Clogged EGR and no CEL
Old Aug 23, 2006 | 03:24 PM
dane's Avatar
I just recently had an experience where I thought that I might be
having transmission problems. When ever my 2001 Rodeo would get to the
speed where it should either shift to or out of 2nd gear it would have
trouble (no power). However, I didn't have a CEL indication.
I took it to the dealer, and it turned out to be a clogged EGR and throttle body assembly.
WHen either of these are clogged, shouldn't there have been a CEL? [img]smileys/smiley5.gif[/img]
Old Aug 23, 2006 | 09:18 PM
ISUZUGURU's Avatar
Super Moderator
YES ,but the egr would set an insufficent flow code when it gets tooclogged .they proably told you that because while they are replacing the t-body the egr passage is very accessably then.they cleaned it now to avoid a future check engine light later an more diag time.the real problem was more than likely the t-body setting a tps failure an going into a reduce power mode.isuzu went to that electronic t-body those yrs.an has been having problems with it ever since.they should have stayed with the gas cable.
Old Aug 24, 2006 | 10:43 AM
dane's Avatar
Thanks.
I have one more question
Where is the throttle body located? Is it connected to the air intake from the air filter?
KDemarest7725
Aug 25, 2010 10:10 AM
HybridFire
Mar 21, 2009 11:06 AM
vaman4215
Aug 28, 2007 06:01 PM
squirt
May 20, 2007 09:56 PM
Aquaholic
Apr 20, 2006 01:13 PM
