check engine code ????
Old May 28, 2011 | 01:31 PM
redflash's Avatar
Default check engine code ????
Check engine light, ran the code .....Says P0440 apparently that code refers to evap sensor. I realize vacuum hoses and some other loose fittings, even loose gas cap.. may be the cause......but before I tear into anything, have any of you seen this code and found either a typical or obvious issue that could help
thanks in advance
gizmo55
Nov 22, 2015 05:57 PM
TonyMESC
IF Help & Suggestion Center
Feb 1, 2010 05:00 PM
gimmneycricket
Mar 11, 2007 10:39 PM
thebeachbumm
Feb 9, 2006 11:35 PM
