check engine code ????
Check engine light, ran the code .....Says P0440 apparently that code refers to evap sensor. I realize vacuum hoses and some other loose fittings, even loose gas cap.. may be the cause......but before I tear into anything, have any of you seen this code and found either a typical or obvious issue that could help
thanks in advance |
