check/ change trans fluid
Old Jul 16, 2005 | 02:15 PM
robdog's Avatar
how do you check the auto trans fluid and refill after drain and filter change?
what kinda of crap is this with no dipstick?
1998 rodeo v-6 auto 4wd
Old Mar 25, 2006 | 12:31 AM
NorCal's Avatar
I had the same problem as you did but was finally able to figure
out how to check, drain, and refill AT fluid. Mine is a 1997 Honda
Passport 3.2L V6 but I believe still uses the same 4L30E transmission
as 1998. There is no dipstick on these models (blame it on GM) but an
overfill plug on the passenger side of the tranny that you check if
fluid is full. The problem is that I had to take out a bunch of stuff
before I could access that overfill plug..grrr...
Anyway, here is the site I went to get info:
http://www.4x4wire.com/forums/showflat.php?Cat=&am p;Number=504751&page=0&view=collapsed& sb=5&o =1&fpart=1#Post505080
quiller
Apr 9, 2012 07:27 AM
joenoble
Mar 18, 2012 12:20 PM
josenangela
Nov 9, 2008 03:32 PM
pedro62
Jan 30, 2008 05:30 PM
AmigoMan
Dec 17, 2007 04:51 PM
