how do you check the auto trans fluid and refill after drain and filter change? what kinda of crap is this with no dipstick? 1998 rodeo v-6 auto 4wd |
I had the same problem as you did but was finally able to figure
out how to check, drain, and refill AT fluid. Mine is a 1997 Honda Passport 3.2L V6 but I believe still uses the same 4L30E transmission as 1998. There is no dipstick on these models (blame it on GM) but an overfill plug on the passenger side of the tranny that you check if fluid is full. The problem is that I had to take out a bunch of stuff before I could access that overfill plug..grrr... Anyway, here is the site I went to get info: http://www.4x4wire.com/forums/showflat.php?Cat=&am p;Number=504751&page=0&view=collapsed& sb=5&o =1&fpart=1#Post505080 |
