blower motor problems
Old Oct 21, 2006 | 08:35 PM
spoon059's Avatar
My climate control blower motor has been making clicking sounds, so I removed the blower motor and cleaned it out. There were a bunch of twigs and leaves on the inside of the housing that I assume were making the noise.
While I was cleaning it, I dropped it and broke the white plastic fan blades. It appears as though there is some way to replace just the plastic blades. Does anyone know if there is a way to replace just the blades, and if so, where I can buy them?
This is a picture of the blower motor...
http://www.partstrain.com/products/E...ate_Control/Bl ower_Motor/2003~ISUZU~RODEO~6~3.2~ROD-V6-004.html?index=0
Old Nov 14, 2006 | 09:54 PM
nate783's Avatar
yes, if it has a c-clip or snap ring on the shaft, remove that, after that it is pressed on, which mean you just have to pry it off, and since you would be replacing it you dont have to be nice about it, it will be a lot easier to just beak it into pieces until you can get it off, to get another one you may find one at a junk yard, but then you have to take it off all nice and old ones are always brittle so it is difficult not to damage it, and the new one would just press back on, i think the easiest route would be to just replace the entire thing, i dont believe it is too much more money to get a motor with the blades, well, hopefully some of my ramblings may have helped, good luck!!
UTDrea
Jun 25, 2020 03:30 PM
Phaser4hire
Jun 8, 2011 12:11 AM
jburgess
Pickup
8
Apr 22, 2008 11:00 PM
WoodyXJS
Mar 28, 2008 02:48 PM
IsuzuKid
Aug 8, 2007 10:53 PM
