Battery or Worse?
Old Feb 3, 2011 | 08:10 PM
heyyalliee's Avatar
Question Battery or Worse?
Hey I'm new to the forums and I just have a general question bout my awesome rodeo.
I have had my rodeo for about a year and have had no major issues. Past two days I have had trouble starting the car. Need a Jump etc. It will start if all the doors are closed. If one door is open all the lights flash and the car won't start. Please tell me this just means I need a new battery?
Thanks in advance for your help!
Old Jul 10, 2011 | 07:35 AM
sdiggz's Avatar
I wish someone answered your question because I had that problem with my 96 Trooper and I would pop the hood and wiggle the battery cables to get it to start. I always felt like the cables were loose at the other end or something but I never found out because the problem stopped.
Old Jul 11, 2011 | 10:27 PM
heyyalliee's Avatar
Lightbulb Turns out
Turns out it was the battery and the cable connecting to be battery. So I got a new car battery and the mechanic replaced the cables and ever since then I have had no problems. If you wiggle them to get car to start sounds like a connectivity issue. I suggest replacing them and see if that works!
-allie
UOTE=sdiggz;46763]I wish someone answered your question because I had that problem with my 96 Trooper and I would pop the hood and wiggle the battery cables to get it to start. I always felt like the cables were loose at the other end or something but I never found out because the problem stopped.[/QUOTE]
Old Jul 12, 2011 | 10:14 PM
sdiggz's Avatar
Thanks! I appreciate the reply. Actually just talked to a different mechanic yesterday about the repair and I suggested replacing the battery and cables. What battery did you go with? I'm actually having issues finding a good mid grade one. The entry levels I've seen are $89 but the next level up is $189. I don't want to go so cheap but I also don't wanna spend $200
Old Jul 22, 2011 | 08:31 PM
heyyalliee's Avatar
I totally understand! I am the same way...I forget which one is in there...but it was the the middle price range. Don't want to spend to to much.
-Allie
Old Aug 13, 2011 | 12:41 PM
speedstick345's Avatar
so it was just a bad connection?
good thing you found you, this is quite common
Davydeycke7
Oct 4, 2012 02:31 PM
chabat
Oct 21, 2007 04:53 PM
tide_belle
Jun 17, 2007 01:12 PM
robdog
Nov 30, 2006 12:54 AM
derek44
Nov 25, 2006 03:38 AM
