ABS and brake light
Old Sep 23, 2005 | 05:47 PM
greenhornet36's Avatar
I have an ABSand brake light constantly on, I already check my brakes twice, I own a 1996 Isuzu rodeo and this one don't even have an ABS, any suggestion and help will be appreciated.
Old Sep 23, 2005 | 06:43 PM
Patrick's Avatar
Super Moderator
check your brake fluid level...the ABS light comes on due to low fluid also.
Old Sep 28, 2005 | 03:13 PM
my fluid level is good and even removed the battery connection to reset all lights but still the light turns on as soon as I moved the vehicle.
Old Apr 26, 2006 | 02:11 AM
slowpoke's Avatar
I have recently experienced the same problem... Brakes are good, no ABS system that I am aware of (92' Rodeo 3.1L V6, 4WD) Mechanic says bad sensor for fluid level probably.
Edited by: slowpoke
Old Apr 28, 2006 | 04:44 PM
ISUZUGURU's Avatar
Super Moderator
IF THE ABS LIGHT IS ON IT HAS ABS.IT MAYNOT HAVE 4W ABS.BUT IT HAS REAR ANTILOCK. LOOK UNDERNEATH ON THE DIFFERENTIAL YOU SHOULD SEE A SENSOR ON TOP.THEY GO BAD OFTEN ON THOSES YRS. AN THERE IS A DIAG CONNCTOR FOR IT ALSO TO FLASH CODES FOR IT...
Old May 16, 2006 | 03:50 PM
Most common problem for those years is a broken wire for the abs sensor. They made the wires too short and it will break internally. Its usually broken wires at a connector near the frame right in front of the left rear wheel.
Old May 17, 2006 | 06:11 AM
ralph08's Avatar
Take a look under your car to check out what really wrong with your brake lights. A little browsing from the net for info and tips can surely help.
greggd1959
Nov 18, 2011 11:48 PM
yhata
Jun 5, 2010 03:23 PM
kdfvwman
Oct 5, 2009 05:16 PM
tide_belle
Jun 17, 2007 01:12 PM
derek44
Nov 25, 2006 03:38 AM
