99 Rodeo - Idle Problem
Old Sep 30, 2009 | 05:53 AM
jafo2k's Avatar
Angry 99 Rodeo - Idle Problem
Normally, I can find solutions here without posting, but I can't seem to find an answer now.
My 99 Rodeo normally idles below 1000. Over a period of 2 days this works its way up to 2500 - 3000.
I have replaced the TPS with no change. If I disconnect the battery for 15 seconds, it works fine for a day or so then the idle problem works its way back.
Any suggestions welcome and thanks in advance.
jafo2k
Nova Scotia Canada
Old Sep 30, 2009 | 05:42 PM
wheily's Avatar
first check and clean your (iac idle air controler) thats what controls idle speed mine keeps geting gumed up for some reason but mine just might have a gremlin living in it
Old Sep 30, 2009 | 05:43 PM
wheily's Avatar
im not sure on yours but it should be up on the fender
Old Oct 11, 2009 | 07:25 PM
kdfvwman's Avatar
Idle speed is controlled by a electic idle speed controller, mounted on the air intake /trottle valve body. Basically it's a electic motor which extends or retracts an air plunger as needed in the air bypass around the closed throttle valve to regulate idle speed.
These things are known to fail or operate eratically!
K Hunter
Oct 5, 2009 09:45 AM
D16z6
Mar 6, 2008 10:16 PM
PedroIsMyAmigo
Sep 6, 2006 07:39 AM
joentraci
May 9, 2006 10:51 PM
buttermantoast
Pickup
May 9, 2006 06:15 PM
