96 Rodeo Tach V6 2WD Auto
I am installing a remote starter on this Rodeo and I need to find a Tach input inside the car. Does any one know which wire and the location? I have tryed to use one of the green wires at the coil on the spark plug but cannot get a good signal.
Thanks
Eddie
depending what brand you purchased you can go without the tach connection,but is your engine coil over plug design? you can get the signal off the ground side of either coil.i,ll have to look at the wiring diagram to tell you which color monday. or if you have an haynes manual it should have a brief wiring section in the back,just find the ignition coils an follow the negative wire.Edited by: ISUZUGURU
