5 speed starting question
Old Aug 19, 2006 | 01:56 AM
Mass Rodeo's Avatar
Hi all,
I have a '92 Rodeo with a 5 speed. Strange starting issue: when I depress clutch to floor, turn key, all idiotslight up, but just one click, no start. If I try it several times, (usually three) it starts as normal. Its usually good then for three or four stops, and starts first time.
I'm worried that one of these times, its not gonna start. Any ideas?
By the way this is my first post, and I am new to the group, but so far it looks like a great forum!
Thanks, SMcD
Old Aug 20, 2006 | 12:31 AM
misfit's Avatar
Sounds like a starter at fault. Sometimes the contacts internally wear out and cause it to just "click". Try an aftermarket starter.
Old Nov 12, 2006 | 11:50 PM
nate783's Avatar
my guess would be the clutch sensor located on the upper part of the pedal, i have had it go out on all three of the isuzu's i have owned, the quick fix it to disconnect it, cut the wires and hook them together, i have done it every time and it works every time, hope this helps
markjw
Oct 9, 2008 12:34 AM
spearbang
Aug 11, 2008 04:59 PM
alanrush2004
May 28, 2008 01:09 AM
tomb981
Jan 15, 2008 10:46 PM
Harleygirl
Jun 15, 2005 05:31 PM
