2002 3.2L can't align camshafts help
Old May 30, 2011 | 06:24 PM
jd318jds's Avatar
Default 2002 3.2L can't align camshafts help
replaced broken timing belt...got it to start but stll not right...all alignment
procedures talks about 9 revolutions worst case...why do each
side line up on marks every 4 rotation...does anyone have correct procedure??? thanks
Old Jun 16, 2011 | 07:57 PM
NCISUZUTECH's Avatar
You will need to time the engine as follows....
Align the notch on the back of the crank gear with the mark on the oil pump housing (3oclock position)
Next you will need to rotate clockwise the right cam gear until the mark "springs" at the 12oclock position. (the marks should be lined up)
Now rotate clockwise the left cam gear (driver side) until the mark "springs" at the 9oclock position then rotate it clockwise up to the 12oclock position (line up the gaer mark with the mark on the valve cover)
Install the belt and you should be good.
Hope this helps.
rottman
Nov 7, 2012 04:28 PM
tjhennin
Oct 15, 2009 05:13 PM
vova
Axiom
Oct 17, 2008 04:02 PM
trooper90
Dec 1, 2006 04:49 PM
Mjaye
Axiom
Jan 24, 2005 12:47 AM
