2001 Rodeo - Check engine light on + flas
Old Sep 14, 2008 | 02:06 AM
Marcony's Avatar
Hi there,
I have 2001 Rodeo. I recently replaced right head and did full tune up. Since than i have check engine light on. I pull codes from OBD tester and I get P1312, P0300, and sometimes P0463, and P1311. I replaced all ignition coils, ignition module, MAP sensor, even I get used working ECU (two of them) and still the same. On moments there is no light on, and then as soon as I push on gas pedal light start flashing and then goes on stady, and flashing again and again...[img]smileys/smiley7.gif[/img]
Any idea what I should replaced next. I m open for any sugestions.
Please let me know if you ever had any problems like this one.
Thanks
Old Sep 15, 2008 | 08:30 PM
Marcony's Avatar
I fix the problem.
Replaced new bosch platinum sparkplugs with oem denso double platinum (Denso PK16PR-P11) and everything is ok. No more CEL.
[img]smileys/smiley4.gif[/img]
Old Sep 16, 2008 | 06:06 PM
Glad you got it figured out. Without looking up the codes my first thought was intake manifold gasket. But yeah, you have to use specific plugs in ''00+ rodeos because of the ion sensing system.
Btw, a flashing cel means there is something wrong that could cause damage to the cat converter.
sammie white
Sep 29, 2011 10:50 AM
collyswamper
IF Help & Suggestion Center
Mar 22, 2008 11:27 AM
ibguyb
Aug 20, 2007 10:00 PM
dane
Jul 29, 2007 02:56 AM
mazur50
Jul 15, 2007 08:01 AM
