2001 Rodeo battery, abs & brake light
I have a 2001 Isuzu Rodeo, 4cyl. Recently just had the head replaced, shortly after that had the manifold intake weldedto seala crack. Now I am facing problems with the battery light and emergencybrake light coming on and today the ABS light came on. The a/c does not seem as powerful as it should be either. There is also a noise under the hood that started along with this, it sounds to melike an ice cream maker [img]smileys/smiley1.gif[/img]. We've been to 3 different Auto parts to check the battery and alternator, two say that everything is okay, one says that the diodes are going bad. Can someone please give me some suggestions. This is mine and my daughter's only way of going. Also, do you recommend factory or auto parts store? Thank you!
Tide_belle
