1999 Rodeo Part Help Please
I found this under my Rodeo on the garage floor. I can't read the part number as the break in the rubber goes through the part number and there is a piece of the rubber missing at the break.
It is a solid rubber material.
Here is the part number I can read.
There is a very small "5" inside a circle, then the rest of the part number...
4-3 8-9437 blank space 448
Thank you
Thank you
Thanks. I searched online and haven't come up with anything.
Do you have any ideas on where to get them? Looks like I may need 2 as well. Thanks.
#8
If that is a bump stop you should have 2 of them... You could get under the car and see if the other one is still there (and if it is complete) remove it and go to an autoparts place, and you may have to buy 2 since that one looks very dry and cracked the other one must be equally damaged.
Daniel Ferguson
09-29-2013 06:13 PM
