1999 Rodeo Part Help Please
4 Attachment(s)
I found this under my Rodeo on the garage floor. I can't read the part number as the break in the rubber goes through the part number and there is a piece of the rubber missing at the break.
It is a solid rubber material. Here is the part number I can read. There is a very small "5" inside a circle, then the rest of the part number... 4-3 8-9437 blank space 448 Attachment 1113 Attachment 1114 Attachment 1115 Attachment 1116 Thank you |
It looks like it may have come off just to the inside of the rear driver's side wheel. Any thoughts guys?
I need one - actually two of those too - those are the stopper bushings preventing the rear axle from hitting the frame, should be bolted onto the frame right over the axle behind the wheels....
Originally Posted by Windy
(Post 50638)
Thanks. I searched online and haven't come up with anything. Do you have any ideas on where to get them? Looks like I may need 2 as well. Thanks. |
no sorry, can't come up with a name for it either. If you ever find out pls lemme know!
They are $65 from the dealer I just checked with. Sorry, I didn't get an exact name on the part.
I looked deeply in my isuzu workshop book and could not find that part.
second time that book has failed me. First was the roof rack dis-assembly, now this. Sorry man. |
If that is a bump stop you should have 2 of them... You could get under the car and see if the other one is still there (and if it is complete) remove it and go to an autoparts place, and you may have to buy 2 since that one looks very dry and cracked the other one must be equally damaged.
