1998 rodeo, no power im stumped
Old Aug 27, 2011 | 08:36 PM
pensacolaisuzu's Avatar
Default 1998 rodeo, no power im stumped
I just bought this truck and it is being very difficult, i see a bunch of threads and google topics with the same problem but i never see where anyone posts how to fix it. It starts and idles fine, normaly, but when i go to drive it has no power, cant go over 30, have to apply the gas very softly if i push to hard on the pedal it boggs down. I thought it was cloged cats so i cut them but it made no difference, the only codes its reading are oxygen sensors but no check engine light it on, it has a new fuel pump, and i can see where someone has removed the intake and put new seals, as well as a new mass airflow sensor and altenator. It is running on all 6 cylinders. I dont know what to do, i think it might have a bad ecm but i dont want to go just buying parts that dont fix it, thanks
Old Aug 30, 2011 | 12:40 PM
Mrose1977's Avatar
Have you removed your EGR valve? Clean it out so that the spring loaded pin moves freely. put it back on and see if it helps. I say clean it first because there not cheap.
redleader
Oct 16, 2010 09:57 PM
lollypop
Sep 19, 2008 06:42 AM
lollypop
Sep 11, 2008 07:03 AM
Dedd2000
Apr 7, 2008 07:44 PM
cowboys78
Mar 28, 2007 09:05 PM
