1995 Rodeo A/C problem
Old Aug 3, 2010 | 02:55 PM
ShutGate's Avatar
Default 1995 Rodeo A/C problem
Greetings,
I have a 1995 Isuzu Rodeo, the A/C has always worked flawlessly until this morning, drove to the store with the A/C working, got back in to leave the store, cranked fine everything working, turn the A/C back on and nothing, no power to the dash control at all
nothing happens no matter what you do, no blower.. not even the blue "A/C" light comes on, checked all the fuse/relays and every things fine, pulled the dash apart to check for any plugs/wires unhooked/broken ect. and nothing seems wrong
checking the relay/fuse again under the hood reveled there is no power to either the fuse or relay, a jumper wire from a working fuse to the A/C fuse and the A/C will come on and work normally
why is there no power to either the fuse or relay under the hood for only the A/C, by no power i mean of course, pulling the fuse/relay and checking with a light tester for fire, there is nothing
is there a switch or something, somewhere that i am missing?
any advise is helpful, and again.. the A/C works fine if you run a jumper wire to power the A/C fuse under the hood
Old Aug 4, 2010 | 05:21 PM
NEUWBEA's Avatar
1995.5 Model Year / A/C Compressor Controls
Check out this schematic
Old Aug 5, 2010 | 03:52 PM
ShutGate's Avatar
problem solved
always seems to be something simple does it not, the heater relay was bad and prevented any power from reaching the A/C relay
never occurred to me to check the heater relay for an A/C problem....
Old Aug 23, 2010 | 11:46 PM
nortontriumphmec's Avatar
Quick question: Were any of the idiot lights on the speedo tacho gauge area illuminated (such as the gas pump, battery, and brake light) when your blower and air conditioner weren't functioning?
Your problem sounds exactly like my problem only I have those idiot lights on, as well. I tried switching the heater relay for the air conditioning relay, but the air and blower is still not working.
I'm going in search for some new relays tomorrow.
Old Jul 8, 2018 | 10:50 PM
chadillac775's Avatar
Default Did you resolve your issue
Did you resolve your issue, how? Was the relay the solution?
Old Jan 11, 2021 | 03:28 PM
Mauqis's Avatar
Default Help
Originally Posted by ShutGate
problem solved
can you guys share with me that diagram? I have the exact same problem. Please help!
Old Mar 31, 2021 | 08:14 AM
Mike4393's Avatar
Default Climate Control
Greetings,
Hello
Might be better to have your original part repaired at upfix.com
Here is the service link
https://www.upfix.com/product-catego...omfort-repair/
rodeodad
Oct 6, 2017 06:28 PM
crasher
Jun 28, 2015 06:16 PM
ejkz
Jan 27, 2012 01:51 PM
malachi1616
Nov 15, 2010 09:58 AM
coldfuzion76
Oct 5, 2009 07:01 PM
