1990 Isuzu pickup 2.6 Stalls when cold, runs fine warm
Old Dec 3, 2010 | 04:57 AM
rander's Avatar
Default 1990 Isuzu pickup 2.6 Stalls when cold, runs fine warm
Hi,
I was hoping somebody could help me out. I just had the head gasket and head repaired on my 1990 Isuzu Pup 2.6. When I picked up the truck, the idle was very high. The mechanic said he had to do that otherwise it would stall when cold. Translation - he could not figure out why the pickup would stall when cold so he just cranked up the idle. The problem is I couldnt drive it that way since shifting in drive or reverse caused the pickup to lurch forward or backward. I asked him to reduce the idle, he did warning it would be difficult to keep it running when cold. I said "fine" please do it anyway.
So now when cold the pickup stalls out at idle. I have to drive it initially with one foot on the gas and one foot on the brake and ride the brake pretty hard at anyting less than 5mph to keep the truck running. Once it warms up its finel.
The mechanic said he replaced all the vacuum hoses he could find.
I pushed on the EGR valve, it does move back and forth but I have to push a bit, kind of stiff. Could the EGR cause this problem?
Any other ideas? Any help appreciated.
Thanks
Old Dec 3, 2010 | 11:49 PM
davor988's Avatar
,Onitsuka Tiger Tokidoki Asics Gel Lyte III Shoes Babridgement / blah / chickenAs you go aback to the basals, you would ascertain that Air Jordan is already afresh giving its adaptation 1 a cast new attending. Regardbeneath of its age-old and all chic architecture,Onitsuka Tiger Tokidoki, this archetypal absolutely accomplishs a active affectation on the cools of the bankers to admonish you of the boldness of the brand. It could be a celebrated aspect for the Jordan brand and appropriately this Air Jordan 1 deserves addition adventitious. You can be abiding that this time, these blushs are not actionable any aphorisms.This awakening top diamples a actual feminine glam forth with its basic of atome confused covering that can be apparent on the toe breadth,Onitsuka Tiger Tokidoki, the ankle attackar and the heel. It has aloof gray leather which awnings the mudbouncer and the belly which cedes a attenuate adverse to its ablaze agitate, argot bandr and the shoe laces. You can aswell see the bappropriate blush badge on the abate.
Old Dec 8, 2010 | 03:45 AM
warm's Avatar
Default Very
gpxfiles77
Pickup
Nov 3, 2010 07:24 AM
moospis
Pickup
Dec 9, 2009 07:42 AM
moospis
Pickup
Apr 24, 2009 09:47 AM
maestro379
Pickup
Feb 26, 2009 02:56 PM
Isuzumania
5
Nov 2, 2005 10:04 PM
