Need a/c High Pressure Sensor for '99 Rodeo
Old Apr 11, 2014 | 11:01 AM
Machwulf's Avatar
Default Need a/c High Pressure Sensor for '99 Rodeo
Greetings all, just found a 1999 Rodeo in decent shape.
My 1st SUV, love the taller ride & handling so far.
I'm a Isuzu newbie in FL, so NEED the a/c, but can't locate the
a/c High Pressure Sensor (mechanic says it's "3 way / 3 pin&quot
Is that the proper name for this part? Anyone have pics of it?
Would like to know best shops /resources for affordable parts
& any advice for stowing 7' wind-sails on the roof rack.
Many thanks in advance for any info / assist!
Old Apr 14, 2014 | 08:34 AM
Machwulf's Avatar
ANYONE? Really just need a link to any trustworthy supplier who might have the sensor. Found condenser from compatible Passport, but dryer wont work since Ive the 4cyl / 5spd manual. If there's an alternate fix Its worth a try. Thanks again
Old Apr 14, 2014 | 10:59 PM
Overnite's Avatar
I was able to find this. If you scroll about half way down the page it lists a high pressure switch for your car. They also have a phone number you can call.
http://www.davesdiscountautoparts.co...?currentpage=2
Old Apr 15, 2014 | 10:55 AM
Machwulf's Avatar
Thanks for the quick reply Overnite, that's the Binary / 2-Pin part on MOST models, mine needs the Trinary / 3-Pin (only found on manual 5-Spd).
Dave's picked up promptly & I learned it's called Trinary, so one step closer.
Knowing (proper part nomenclature) IS half the battle, yeah? Thx again!
Old Apr 17, 2014 | 10:34 AM
Overnite's Avatar
I hope you have had some success with this but in case you haven't, this is what I have been able to find; according to AllData, the OEM part number for the Trinary pressure switch for a 1999 Rodeo with a 2.2L engine and manual transmission is part no. 8971482280. The link below lists these and they are a little expensive but I would give them a call and see what you can find out. You might want to have your VIN number before you call just in case. I hope this helps. Just put the part number in the search toward the bottom of the page and it will take you to the listing.
http://www.isuzupartscenter.com/part...?siteid=216496
Old Apr 18, 2014 | 12:08 PM
Machwulf's Avatar
That's exactly it . Your Sherlock skills are awesome, thanks for digging that up - I've looked at over sixty sites, shops, recyclers etc. TEN TIMES more expensive than the standard binary part, but means I can use this truck through the summer here in FL. (Mainly to get OUT of this bloody oven). Thanks for the save Overnite!
Old Apr 18, 2014 | 01:10 PM
Overnite's Avatar
Glad to help. Stay cool!
seibob
Nov 1, 2019 11:55 AM
ValerieMc1
Sep 30, 2010 08:22 PM
rangerxtrn
Jun 26, 2010 06:14 PM
alajones
Aug 13, 2009 04:58 PM
jrandallc
Sep 25, 2006 09:49 PM
