Door lock jammed
Hi friends, I have fixed up a 92 4x4 by using a 91 2x4 that had hit a tree. Mine had over 300,000 km. on it and the wrecked on only had 137,000 so a motor swap was a great deal. The other day I locked the doors and slipped into to pick up a paper. When I came out my key would not unlock the driver's door. Ended up climbing over the gear shifts.The **** will not pull up on the inside so now I'm stuck climbing in and out thru the pass. door. Can't pull the door panel off tho I have tried since the way it fits keeps it inside the door jam for most of the edges. Shone a light down inside but can't see anything wrong except that the rod will only come up a little and then it is like a strong spring and will not unlock. Anyone else had this problem and no a solution. Thanks!!!
PS> Need this for all the snow we get up here in the cold cold North.
[img]smileys/smiley2.gif[/img]That happens on my '90 some times! What I've done is slip the tube on wd40 inside the door, and spray around the best I can. Then while my wife tries pulling up on the button, I keep trying with the key in the lock. After several attempts, it usually unlocks! I've talked to the local dealership, they're stumped! Give it a try, hope it works for ya!
What's the DEAL?!?! Why's it getting so hard to get parts? Speedo cable went out on my '90 pickup 3 weeks ago, dealer keeps telling me it's backordered and Isuzu won't give them any idea when it will be in! AND, of course it's one of those " Factory Only" supplied parts! [img]smileys/smiley7.gif[/img]
