Isuzu Pickup, i-350 and 1-280 Talk about Isuzu Pickup related topics here...
4wd will not engage
Old Apr 28, 2021 | 04:35 PM
ibradbury's Avatar
Default 4wd will not engage
Hi, I have a 2014 d max with automatic gearbox. The issue I have is that the 4wd will not engage. I can hear the motor trying to engage but it winds in a bit then out, then retries a few times before giving up and displaying a 4wd fault light. I have checked the front axle motor is ok, this works if provided with separate power supply and also the feedback switch is working. I removed the motor from the gearbox and checked that there was not any major resistance to engaging 4wd. All seems ok but the motor only rotates a small way and then goes back. Any advice would be appreciated. Also, does anyone have a wiring diagram for this system as I would like to do a pin to pin check of the wiring to make sure there is no damage between the 4wd motor and the ecu. Thanks in advance.
Jonwilko
Jan 17, 2018 09:10 AM
fireaxefd
May 8, 2017 03:12 PM
Kappu411
Nov 10, 2010 11:15 PM
coleman
Mar 5, 2010 02:30 PM
gmeade44
Mar 2, 2010 08:27 AM
