4wd auto button
Old Apr 24, 2017 | 07:36 PM
fireaxefd's Avatar
Default 4wd auto button
Hi. Thank you for taking the time to look at my post. I am having trouble with my 98 trooper with the 3.5L. It has push button 4wd. with a gear shifter for high and 2L. My problem is, the last time I put it in 4WD the button stopped working. On the dash it shows all four tires lit up in full 4WD not On Demand. the AUTO light is not on. it is definitely in the HIGH position. When I push the button nothing happens. I have not heard anything trying to actuate. Has anyone ever had this problem? (my luck is renowned for "I've never even heard of this happening before") I've searched all over for something to give me a clue. No fuses seem to be attached to it. relays? any ideas? very much appreciated! Thank you!
Old May 8, 2017 | 07:34 AM
fourwd1's Avatar
Does the display show 2WD mode when bother the button and the shifter are in 2WD Hi ?
Old May 8, 2017 | 07:36 AM
fourwd1's Avatar
From what you describe it sorta sounds like you're in 4WD Low mode but the tcase didn't actually shift to Low range.
Old May 8, 2017 | 03:12 PM
fireaxefd's Avatar
Default RE:
No . the display is showing 4wd.
"From what you describe it sorta sounds like you're in 4WD Low mode but the tcase didn't actually shift to Low range."
I will put it back in forth in low range and get back.
Thanks for the replies!
andym
Jan 20, 2016 06:29 AM
Doyle225
Jan 7, 2015 04:36 AM
jamracer21
Mar 19, 2010 03:28 PM
judgemint
Sep 8, 2009 02:50 PM
yhperformance
Aug 29, 2008 03:17 PM
