strong fuel smell
My son's 1993 Rodeo just developed a strong fuel smell that can be detected as you approach the vehicle. When you lift the hood, it is even worse. What could be causing this smell? No leaks are noticable.
hard smells are usually caused by melting rubber hoses, a burning coolant, plugged </span>catatalytic converter,
and leaks which you've said are not visible. or probably some problem
with the fuel lines. those are just a few things to check.</span>
Edited by: n0walker
TM2001RODEOSE
Oct 15, 2011 07:12 AM
