Rear Brake Pattern on 2001 Trooper
Old Jul 8, 2008 | 07:04 PM
rhartmann's Avatar
I have a 2001 Trooper and recently had all the brake pads replaced. The front rotors look nice and shiny after braking and the brake pads cover the entire flat surface of the disc rotor. However, the rear rotors look much different. The entire braking surface of the rotor is not being used. So when you look at the rotor you see a unused (not shiny) area about 3/4" in width right next to the outside perimeter of the rotor. Also, there is a another 3/4" area (not shiny) on the rotor right next to the hub. Is this normal on the rear rotors? I took the vehicle back to the shop that did the work, and they said everything is normal.
Really?
cfoss75
Apr 12, 2011 07:40 AM
LBurnash
Aug 7, 2007 10:41 AM
BillTrooper
May 1, 2007 09:47 AM
houptee
Jan 3, 2007 10:09 AM
passport105
Aug 13, 2006 02:30 PM
