oil leak/pressure problems
Old Jun 23, 2011 | 03:11 PM
roland's Avatar
Default oil leak/pressure problems
Hi,
Can you please help me, I have just bought a trooper 3.1 TD, the engine sounds sweet it has just had a new cam belt and been recently serviced, but the is a problem with oil leaking: pumping out of the dip stick tube, if i take the oilfiller cap off the pressure seems really high and oil spurts out. any ideas what this is and how it can be sorted?
thanks in advance
Roland
Old Jul 13, 2011 | 09:31 AM
pansi's Avatar
Oil leaks could be as a result of crankcase breather when the pressure in the crankcase increases. Usually, the weak spot is the front oil seals but if it has been badly blocked, I think the other sealers would blow as well.
I am almost certain that your problem is with the crankcase. Check if the dipstick rises when the engine is running-this is an easy way of identifying whether the breather is not functioning well.
You can sort this problem by replacing the breather box or by cleaning it since it may be clogged up with oil. Hope you get the problem sorted out!
Old Jul 14, 2011 | 11:17 AM
roland's Avatar
thanks alot, that has sorted it out
sicilian68
Sep 24, 2007 03:23 PM
sicilian68
Sep 17, 2007 08:42 AM
SteveP
Pickup
May 19, 2007 07:28 PM
MS39047
May 11, 2007 01:05 PM
Axiom35RT79
Axiom
8
Dec 5, 2006 12:10 AM
