Idle/carb/tuning problems- 91 2.3L pickup
Old Jun 17, 2007 | 10:15 AM
AustinIsuzupiup's Avatar
Under normal driving conditions, at approximately 2500-3000RPMs, when Idisengage the engine/push in the clutch as I approach a red light, my engine will "struggle" as it drops in the rpms and will often stall because it won't idle correctly.
I've tuned the fuel and idle screws in various positions and nothing seems to eliminate the problem. It idles relatively well but stalls under driving conditions.
My truck also failed the Texas emissions test too, going way over on hydrocarbon emissions at idle but ironically passing on the carbon monoxide portion.
Anyone out there experience this problem or have any advice?
Old Jun 18, 2007 | 09:06 PM
crashjt's Avatar
Hey just from my personal experiance those carbs are horrible if you have any kind of miles on it you might consider an overhaul on the carb or even a new one that will most likely fix your problem a cheaper possability would be the coolant temp sensor any light coming on ?
Old Jun 18, 2007 | 10:17 PM
The previous owner installeda recently rebuilt carb (I'm assuming it's identical to the carb that was on there.)
Another 91 Isuzu pup owner told me he had a similar problem and his truck ran much better after installing a new Mixture Control Valve.
Know about this?
suzan_driver
Pickup
May 1, 2012 02:00 PM
zuper89
Pickup
Dec 29, 2008 01:18 PM
hagg1111
Pickup
6
Nov 6, 2008 11:35 AM
Craig
Pickup
Oct 29, 2006 11:47 AM
buttermantoast
Pickup
May 9, 2006 06:15 PM
