Problems with 92 Pickup
Old Dec 11, 2008 | 02:33 PM
zuper89's Avatar
I recently removed the head to find two burnt exhuast valves. Had em replaced and checked the head for cracks and none were found. Put the head back on set the timing and no luck. Turned over and backfired a few times. No start. people tell me everything is in right order. Anyone know what else could cause this. Maybe spark plug wires not placed right?
Old Dec 26, 2008 | 06:52 PM
JLEMOND's Avatar
IF IT IS BACKFIRING IN THE CARB OR EFI UNIT YOU HAVE THE CAM TIMING OFF, THIS ENG TIMES OFF NO 4 CYL NOT NO ONE, IF YOU LINED UP ALL THE TIMEING MARKS ON THE CAM AND THE CRANKSHAFT AND THEN PUT THE DIST IN ON NO ONE IT IS 180 DEGREES OUT, LINE UP THE MARKS AGAIN AND PUT THE DIST IN POINTED TO NO 4 CYL, AND IT SHOULD LITE RIGHT OFF. JERRY
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
window.onload = SymOnLoad;
Old Dec 29, 2008 | 01:18 PM
DJ_Rob_E's Avatar
[img]smileys/smiley4.gif[/img] [img]smileys/smiley4.gif[/img] jerry has a "newbie" title on here wow that couldn''t be anything further from the truth [img]smileys/smiley8.gif[/img] [img]smileys/smiley8.gif[/img]
suzan_driver
Pickup
May 1, 2012 02:00 PM
AustinIsuzupiup
Jun 18, 2007 10:17 PM
sileighty77
Pickup
Dec 14, 2005 12:19 AM
Isuzumania
5
Nov 2, 2005 10:04 PM
doc182
Aug 31, 2005 11:56 AM
