CAS R+R
Old Jun 24, 2007 | 09:38 AM
sean007r's Avatar
First time post here so be nice...[img]smileys/smiley2.gif[/img]
Anywho... I just picked up an '88 Tooper for $100
Overall in good shape except for one driveability concern.
Sometimes it starts and runs fines, other times it is a normal crank no start. Furthermore, when it does start and run normally, it will eventually, within say 10 minutes, stall and not re-start.
This is the reason I was able to buy this so cheaply.
My diagnoses found that during the crank no starts there was no spark. Digging deeper I found no pulse to the coild. All this lead to replacing the CAS (crank angle sensor). However, I was only able to find the CAS sold with the dist.
So cool... r+r the dist and I'm done. NOT![img]smileys/smiley7.gif[/img]
Now I can't get the thing started at all.
So I pulled the dist, set the crank timing mark at 12deg BTC and stabbed the dist so the rotor points to #1
Still no start.
I tried several different combinations for cap/wire combos but still have a no start.
Is there a computer re-learn method or something?[img]smileys/smiley5.gif[/img]
sean007r
Jun 26, 2007 06:55 AM
