Aisin trans slipping
Old Nov 15, 2023 | 04:58 PM
Naudio's Avatar
Default Aisin trans slipping
2005 NPR. Trans works fine for 3-5 minutes then slips like there is very low trans fluid and won't move. After a few minutes it will move a short distance again. Ideas? Thanks
Old Nov 16, 2023 | 07:13 AM
kingpintruckrepair's Avatar
Default Check
First check fluid level - if ok then Take clear bottle drain little bit fluid, watch and smell it - if dark, burnt and muddy - internal clutch worn or water intrusion into filling neck - then probably you need transmissions rebuild. Also what's transmission service light on dash illuminate - orange or red
Jonathan James Enos
Jul 26, 2019 05:53 AM
alhe73
Jul 11, 2009 03:42 PM
tccjmo
Mar 30, 2009 11:25 PM
shawner
Jan 8, 2009 01:56 PM
ruskyplayer
May 16, 2006 12:53 AM
