4x4 light flashing
Old Oct 22, 2011 | 07:35 AM
The Money Pit Amigo's Avatar
Default 4x4 light flashing
Also have a blinking 4X4 light 99 Amigo. Have checked all the vac lines and everything seems to be fine. Replaced the 4x4 sol on the drivers side firewall and it does not appear to give vac on the 4x4 (gray connector) when button is pushed. When the vac lines are swapped the 4x4 does engage when the button is pushed but still blinks. I do get voltage to both the gray and the blue on the sol. It just appears that the button is not closing the blue and opening the gray sol when pushed. The blue always has constant suction.
I did just find the Diff switch wires on the front axle were rotted and not connected. I ordered a new one but i do not think it is causing the issue from what I have read in other threads. Just for the hell of it i removed the 4x4 control under the center rest and inspected it for shorts and it looks ok.
Old Oct 29, 2011 | 07:49 PM
Black99Amigo4WD's Avatar
I have a the same truck and mine will not start and the truck will not move even in neutral. It cranks and the 4WD light flashes but no start and cannot get it to move no matter what.
Guys on other forum say I should disconnect motor on side of transfer case and then put it in neutral with pliers just to get in to a garage.
Wish I had known this was really a GM product when I bought it new! A repair every six months with this truck and the frame is as rotted as a thirty year old salt truck!
Old Nov 2, 2011 | 11:26 AM
electricpuppyboy's Avatar
You'll probably have more luck here:
http://forum.planetisuzoo.com/
It's a much more active forum, and not as much spam either.
Old Nov 14, 2011 | 07:34 PM
paulmiller156's Avatar
Hey I liked your same truck post & I hope you will get sell this on good time !
Old Dec 13, 2011 | 01:32 AM
jakelarson's Avatar
Old Jan 5, 2012 | 12:32 AM
ethanvalit's Avatar
Old Jan 13, 2012 | 09:40 PM
Taylorcarter's Avatar
rmac
Mar 14, 2021 03:50 AM
big tom
Apr 6, 2011 02:30 AM
mananambal
Sep 22, 2007 07:48 PM
rmac
Aug 16, 2007 09:31 AM
