3.2
Old Dec 12, 2006 | 07:42 PM
biglou's Avatar
will 3.2 motor from a 2001 rodeo bolt up into 99 amigo and are the sensors the same
Old Dec 12, 2006 | 08:52 PM
MASTERTECH's Avatar
it is the same but use the intake from the 99 eninge and the sensors
Old Dec 12, 2006 | 10:02 PM
biglou's Avatar
okthanks some one told me that they use wireless sensors or something that I would have to tap and thread block and install sensors
Old Dec 15, 2006 | 07:32 PM
ISUZUGURU's Avatar
Super Moderator
maybe the knock sensor,i think it has one that yr under the intake,also the cam sensor on back of the left head would need to be wired up.2001,2002,2000 isuzu started elimnating those sensors around those yrs,i recently replaced an engine harness an it didnt have the cam sensor connection so i wired one in to the pcm.you will need a wiring diagram to do it if you run into this problem.but mechanically its all the same from 99-2003.except the 03 are updated for the oil consumption,which will still even swap perfectly.just some sensor you have to work around.
Old Dec 15, 2006 | 08:30 PM
biglou's Avatar
Thanks
