ISUZUGURU |
12-15-2006 07:32 PM |
maybe the knock sensor,i think it has one that yr under the intake,also the cam sensor on back of the left head would need to be wired up.2001,2002,2000 isuzu started elimnating those sensors around those yrs,i recently replaced an engine harness an it didnt have the cam sensor connection so i wired one in to the pcm.you will need a wiring diagram to do it if you run into this problem.but mechanically its all the same from 99-2003.except the 03 are updated for the oil consumption,which will still even swap perfectly.just some sensor you have to work around.
