Isuzu 4ez1 Rodeo (1996) Ignition Timing Lock question
Old May 9, 2010 | 04:24 AM
AUSJohn's Avatar
Default Isuzu 4ez1 Rodeo (1996) Ignition Timing Lock question
Hi everyone,
Ive done a search but cant seam to find any info for this.
I don't have the factory manual as it got wet and is no longer of any use.
I had the engine replaced not long ago by a auto dismantler, it was running rough so i advanced the distributor. It now runs smoother but no where near perfect, I need to know which conector or wires i need to bridge etc to get the ECU to lock the timing so i can correctly set the base advance on the distributor.
I don't want to remove timing covers, etc etc. Id rather bridge a connector and do it correctly. I can't see any vac lines running to the distributor so i assume its electornically controlled.
Any help would be great,
Thanks
Chewie12537
Hombre
Jan 9, 2015 02:30 PM
Chewie12537
Hombre
Jan 9, 2015 02:28 PM
morphix
Apr 1, 2012 11:15 PM
daroutergod
Private 'Wanted' Classifieds
Apr 25, 2009 12:56 PM
daroutergod
Apr 25, 2009 12:42 PM
