Im wondering what All of you have your tire pressure set at? Ive noticed my average MPG have been getting lower ..... ??? ....? I am trying to find Ways to improve my MPG in Any way... Tire PSI seems to be a good start on this. Thanks every1[img]smileys/smiley2.gif[/img] |
35 is the max (safest) tire pressureDO Not go above it or your chances of having a blow out or worse go up
On my Yokohama tires I have 28 psi. Check your gas station to see how much ethanol is in the gas. With no ethanol I get 19.5+ mpg. With ethanol now I get 18 to 18.5 at 10% ethanol. The higher the ethanol content the more my mpg drops. Some stations have 15% or more around here. (SE Pa). Don''t forget to use fuel injector cleaner once a month. Also a clean air filter helps.
