newbie putting 92 engine in 91 Amigo
My hubby and I are putting an engine from a '92 Amigo into a '91 Amigo body. We are looking for some pictures of one that is put together ('92 engine that is) as there is an a/c tenstioner/pulley that we aren't sure where/how it mounts. Any help or direction would be greatly appreciated.
Thanks [img]smileys/smiley1.gif[/img]
From 89 to 94 the amigos are pretty much the same except for
engine size,2 or 4 wheel drive and auto or manual.
Stand in front of your amigo and look down at the ac compressor
just down and to the right there are two bolt holes in the
compressor bracket that bolts to theblock
this is where the ac tensioner bolts tothe bottom of the compressorbracket
loosen the pulley,put the belt on,then adjust the tension 1/8 inch
vertical play (approx) tighten the pulley nut and youre done.
Caution! do not overtighten! the belt!Edited by: AH ME GO
